Limit on number of simultaneous GET_X instructions in a S7-300?
sanger
Nov 2005
Toronto
172
I need to transfer several hundred bytes of data from two different S7-300 PLCs to a central S7-300 PLC over an MPI network. I am using the GET_X instruction to transfer the data.
Since the size of the data being transferred is more than the maximum 76 byte limit of the GET_X instruction I need to use several GET_X calls to get the data. Can I invoke more than one GET_X call to the same remote PLC at the same time or will I have to make one call, wait for it to complete, make the second call etc.
Is GET_X the best way to do the job. I can find very little documentation on this instruction.
Great references from other responses. If it were me, I would sequence them (wait for each to complete) since that allows you to send an unlimited amount of data. There are strict limitations about the number of simultaneous puts/gets that are cpu-dependent - so i just avoid that whole issue and do them sequentially. Is still quite fast that way: each GET completes in one or 2 scans, if I recall (not dead sure about that, lousy memory, and my use was over Profinet - test it).
Hello all When i look at the panelview specs, it says : Standard Version Offers display sizes from 4...15 in. with wide screen and keypad...
2,043
Hello there guys! I am working with Motorola RTUs and they way it arrange it's data base is through tables. I was told to integrate two...
1,697
Hi Folks, I am using InTouch SCADA (Not Application Platform) and want to know how I can configure the Alarm Banner so that it will only display...
2,010
Dear forum members, By reffering to the blue labelled command on the attached file, Could you tell me what PLC register that is being limited by...
76
Good day: I am wondering if anyone has experience with the Kinetix 5500 S33 Fault. I have 3 drives in a group set as follows: 2198-H025-ERS2...
199
