Limit torque on servomotor
aand74
Dec 2005
Deinze
131
We have aspindle that we drive with Siemens Sinamics S210 servodrive and servomotor1FK2104-4AF10-0MA0 and gearbox 2KJ3500-1CA01-0AM1-ZD11+K08+L02+L75+Y00. The servomotor has a static torque of 1.27Nm and maximum torque of 3.75Nm. The gearbox is a two stage bevel gearbox with a ratio of 11:1.
We havecalculated that the output of the gearbox will have to deliver about 2.2 Nmduring normal working cycle.
The spindle can stand up to 9 Nm before it would break.
We do positioning jobs with the spindle. We will have only mechanical fixed endstops,no electrical sensors for endpositions or home position. Mechanical stops
are very strong build, the spindle itself will be the weak factor if collisionoccurs.
I see the gearbox has ratio 11:1. Static torque of motor is 1.27 Nm, maximumtorque 3.75 Nm.
We should want to home the motor (in case it is mechanically displaced) byletting it travel to the outer mechanical stop, with reduced torque (as isforeseen in the technologyof the Siemens S7 1500 plc). We also should want during normal operation limitthe maximum torque. This for the cases where there would be a positioning faultand the spindle
would drive to its mechanical limits.
The question is : will the motor sense the torque limit, taking In accountthere is a gearbox mounted (it is a bevel gearbox, not a planetary) We wouldprobably limit the maximum torque onto the spindle to 4 Nm,
this would be about 0.4 Nm on the motor. I know from projects in the past thatwhen a gearbox (with high ratio) is mounted that it is sometimes difficult tolimit on that torque because the gearbox absorbs already a lot of torque.
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
91
Possible dumb question here, but how does running a motor through a gearbox effect a VFDs ability to limit the torque on the driven load? My gut...
528
Hello, I am working on an application that inserts a splined shaft into a 'gearbox'. The shaft is rotating slightly to allow engagement of the...
1,280
Hi: I am working with machines that presses flares on steel brake lines. The lines are clamped between a stationary die and a moving die. There...
1,265
Hello, I have a application where I accelerate/deccelerate tires mounted at a spindle. That tires can be different sizes with different inertia...
1,240
