Logix 5000 Clock Update Tool
cyoung120
Jul 2013
OH
92
Hi guys. Hoping someone can give me a hand, or at least point me in the right direction.
I have the Logix 5000 Clock Update Tool version 2.4.2 installed on a Windows 7 HMI server. I have several ML and SLC that are all having there time synched correctly. I added a L72 to the list of devices that I wanted to be synched, manually synched, and got an error that said it was unable to connect and the time in the L72 jumped by like 4 hours. I then went to the L72 controller properties to fix what I had just did and noticed that there was a check box that said "Enable Time Synchronization". So I checked that, hit apply and tried again. Same result.
Do I need to make the L72 a time slave and have the server the "grandmaster clock"? If yes how do I go about this? I tried knowledgebase and didn’t have any luck. Any help would be appreciated. Thanks in advance.
Hey everyone, I want to add the clock into my RS Logix 5000 program. Looking at other threads, I learned to use the GSV command, but I still...
9,567
Hi to everybody, i've a problem using Logix 5000 Clock Update Tool, i'm trying to synchronize a CompactLogix clock but the applicantion always...
7,663
Dear Kind advisors, I need help on the title mentioned subject. The logic i wrote as attached is working and will update the CPU time clock after...
14,924
I need to control a water solenoid to turn on for an hour in the morning and an hour at night 7 days a week. Is there a function in RS Logix 5000...
3,487
I need a clock for a 1756-l72 ver 20. I can not use the wall clock because it is used for reporting. i need a clock that the time can be changed...
2,124
