RS Logix 5000 clock function
Terrep
Nov 2007
Sydney
38
I need to control a water solenoid to turn on for an hour in the morning and an hour at night 7 days a week. Is there a function in RS Logix 5000 I can use?
Hi
Not one on its own that I know of.
You could use the plc time by using a gsv instruction and then with two lim instructions. This would get the result you want
Donnchadh
You need to define a 7 element DINT array with the tagname DateTime (you can call it what you want, I call it DateTime)
Then using a GSV instruction set the class name to WallClockTime, Attribute to LocalDateTime, and Destination is DateTime[0]
GSV WallClockTime,,LocalDateTime,DateTime[0]
DateTime[0] will be the year,
DateTime[1] will be the month,
DateTime[2] will be the date,
DateTime[3] will be the hour in 24hr format
DateTime[4] will be the minute
DateTime[5] will be the second
DateTime[6] will be microseconds
Now using compare or LIM instructions you can create a rung to turn on the valve.
Example
BST EQU DateTime[3] 7 NXB EQU DateTime[3] 19 BND OTE SolnValve
Will turn on the solenoid valve when the hour is 7:00am and 7:00pm
Terrep, the above lines from TConnolly are examples of the ladder logic to perform the task he described.
1)Copy the first line above
2)Add a rung in Logix5k
3)Double click on the rung number
4)Look for the text entry just above the ladder window
5)pPaste the text into that text box
6)Click the check box (or hit enter) to the left of the text entry
7)Repeat with the next line above
You will either need to create the tags that TConnolly provided, or modify them to fit the tags you may already have (like the solenoid)
Hey everyone, I want to add the clock into my RS Logix 5000 program. Looking at other threads, I learned to use the GSV command, but I still...
9,562
Hi to everybody, i've a problem using Logix 5000 Clock Update Tool, i'm trying to synchronize a CompactLogix clock but the applicantion always...
7,655
Hi guys. Hoping someone can give me a hand, or at least point me in the right direction. I have the Logix 5000 Clock Update Tool version 2.4.2...
4,761
Dear Kind advisors, I need help on the title mentioned subject. The logic i wrote as attached is working and will update the CPU time clock after...
14,917
I need a clock for a 1756-l72 ver 20. I can not use the wall clock because it is used for reporting. i need a clock that the time can be changed...
2,124
