phuz
I'm sure I'm missing something here, but can't figure out when it happened or how to remedy it.
I need to compare some Logix5000 files (v16) but for some reason, the compare tool no longer exists in the start menu or in the tools menu in Logix. I tried to open the Logix Designer compare tool, but it tells me the correct version is not installed, and I assume this is because Logix designer is for >= v21. So I downloaded the Logix 5000 compare tool and tried to install it, but it tells me a newer version is already installed.
As a temporary fix, I can fire up a VM and run it on an older install, but I would like to resolve this.
Thanks.
Thanks.
