Logix Designer: Routing via L83ES
Jeebs
Feb 2007
Leuven
1,059
I have a machine set up with a L83ES and a ENBT/A Ethernet card in the rack. Ethernet card is connected to plant network. L83ES internal Ethernet is connected to various IO's, drive, PV's and a L330ERM CompactLogix.
NOTE: the ENBT/A card is in the rack, but not in the PLC configuration. As the card was added later because the OEM did not listen to my requests. It does not need to be in the config to allow connecting to the rack.
How can I connect to the CompactLogix using the plant network and the L83ES as some kind of router?
RSLinx (4.11.00 CPR 9 SR 11.0) does not show me anything beyond the L83ES's internal reference. Ethernet driver > ENBT/A card with external IP > Backplane > Slot 00, L83ES module > A/Ethernet > L83ES module with internal IP.
FTView (8.00.00 & 11.00.00) transfer utility shows me everything beyond that. It shows me everything on the "A/Ethernet" bus. All the PV's, the Stratix switches, the AENTR/B Ethernet adapters and the L330ERM. This allows me to up-/download/compare the PV applications, so communication is possible. Just not via RSLinx
There must be some kind of setting/config I'm not seeing. If any of you can help me out here, I'd be so grateful.
DISCLAIMER: I ain't a systems builder, I maintain/modify existing systems. What I know I've learned myself. The solution might therefor be ridiculously simple.... I just ain't seeing it.
I am not sure if this wasn't for the EN2t, but if you right click on the Ethernet driver of the module, there should be option to add the IP addresses, that you want it to route.
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
251
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
144
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
142
Hello all, I'm trying to use the Logix Designer SDK to upload and download a single ACD to many controllers. I got this to work fine copying...
76
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
241
