Max DP Connections for a Ktp600 Basic HMI
beethoven_ii
Nov 2006
Central England
409
I have a customer who has 6 packaging lines I installed a couple of years ago. Each line is set up with a Siemens Ktp600 basic colour DP HMI screen but they have sourced a spare and would like me to create a hybrid project from all 6 and install it at the palletiser end of the line to give them some visibility on what is happening on the conveyors feeding into the palletisers. My 6x S7-300 plcs are all networked together on MPI and so this shouldn't be a problem. I'm aware of the limitations in tags and alarms etc on the basic range of screens but am not sure if there is a limit on the number of connections that can be configured for a single screen. Does anyone know the answer to this before I commit to a cost for doing the work?
What is the maximum number of PLCs anyone has ever connected to a PanelView Plus 7 Performance terminal AND had the FactoryTalk application still...
2,142
Hey All, We have been having some EN2T modules (all same, up to date, firmware) experience communication drops. Odd thing is that RSLinx and...
3,560
Hi,i am in the process upgrading a PLC5/80E System.Current system is consist of 1 SCADA (Citect) and 6 Panelview 1000 with RIO Protocol. The plan...
2,891
Hello, Wondering if anyone here remembers how to set the maximum number of S7 & MPI connections allowed for a PLC. I feel like it should be in...
4,277
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
153
