Measure pulses/sample - Accuracy
dandrade
Jan 2004
374
I have another solution that is based on timing a number of pulses but solves the problem of the measurement period increasing as the speed of the pulses falls. It has only really become viable now that we have fast PLCs with floating point maths . Decide on an ideal sample time, say 1 second. Give the system a start number of pulses to count, say 50. Time how long it takes to reach this set point using a high speed counter, interrupt and a millisecond timer. The result is unlikely to be 1 second so use the error between ideal sample time and actual sample time to calculate a new set point for the high speed counter. The accuracy of the system is no longer determined by the number of pulses received but by the accuracy of the PLC timer. The system will give the same results getting one pulse per second or 10,000 pulses per second.
Main about,influence variation frequency to effect variation precision. Please, dont know exact phases. Remenber,have method to correction, abandoned not get "more performance". Please describe more clear, method in top.Expose calculus , discusion method get "more performance and precision". (graphics or maths, easy get direct information :) )
Below is a graphic showing two different encoders, one gives 100 pulses per metre and the other 400 pulses per metre. If you needed an absolute measure of length then the 400 would be accurate to 2.5mm, the 100 would be to 10mm. So more pulses more accuracy in absolute measurement. But if you are measuring speed and the PLC can cause an interrupt after a specified number of pulses and has a 1ms timer then you get the same accuracy from both encoders, as shown below:
Hopefully this explains what I meant by 'same results from one pulse or 10000 pulses'. I will take a little time to prepare an example of the maths and the set point recalculation.
Bryan
How can I find the cycle time of an input pulse. The cycle time varies with the process and I need to continuously compute the time. I am using a...
4,701
Greeting experts! We have a new machine we just built. It is equipped with regenerative drives. The machine uses Beckhoff controls (PLC and...
1,093
Hey all. I have decided, for my own curiosity, that i want to know, and chart, exactly how much power my air conditioner actually consumes. And...
1,633
Hello to all, I don't have to much experience in the PLC. I'm using the Studio 5000 v32.03 We are trying to measure the length of a product, in...
1,149
For part of our test system, we need to measure water level inside a chamber, which is under vacuum. We were successfully using one of these by...
112
28,277
