Melsec FX2N and MelsecExplorer (OPC Server)
ronnyh
Oct 2003
Hello
I'm trying to link up MelsecExplorer and Melsec FX2N:
Is it possible to connetc the MelsecExplorer to the programming port (CPU port) on the Melsec FX2N, by using the programming cable SC09?
Do i have to upgrade MelsexExplorer?
Technically SC09 should work
But I had few porblems (I used FX1N):
First if I installed program as a service, I colud not get communication.
Reinstalled to run as a program - works OK.
After that I installed MELDDE, it stopped working again.
Did not have a time to find out why.
My problem is first the configuration of MelsecExplorer: Do i have to configurate the com2 port or do ihave to use the Melsec Inteface Board?
FX2N port is RS422 port.
Computer port is RS232 port.
You need some kind of RS232/RS422 adapter:
SC09 or FX2N-RS232-BD or Third party cable/adapter.
In your software you have to specify port you connect this adapter.
You can get cheap Mitsubishi converters, adapters cables at www.plccables.com
Thank you for the help so far, but i still got the problem.
I'v tryed to reinnstall MelsecExplorer, but it made no differense.
But where do i choose to make MelsecExplorer run as a program and not as a service?
OK this is what i got:
Pc with MelsecExplorer installed and a MelsecFX2N 32MR.
To connect the PC and PLC i use the SC-09 (RS232/RS422 converter).
The SC-09 is connected to com2 on the pc and the programport on the PLC.
So my problem is how to configurate MelsecExplorer. In port setting i use this comport settings:
Port nr: 2
Baudrate: 9600
Parity: None
Flow: Hardware
Data Bits: 8
Stop Bits: 1
When i trying to connect i got these error massages:
Time Out Error (Wait=12 / got=12)
Recieve framing error
Do i have to configurate the PLC too?
Here is the answer:
MelsecExplorer-FX2N
To communicate with the FX2N by using the CPU port you need the CS09 cable and MX-Link to run beside MelsecExplorer.
MelsecExplorer can not communicate with te CPU port on the FX2N ditectly.
I've worked on one Mitsubishi PLC in the past 40 years. Now, it looks like I get to tackle another one...using GX-WORKS3-C1 software which I...
952
I have been asked to work on a Mitsubishi Melsec FX2N-80MR PLC but have no experience with Mitsubishi at all. The hope is to get online to find...
1,340
Our theater’s house curtain controller has a Mitsubishi Melsec FX2n PLC in it that was installed back in ’02. The back up battery failed and of...
1,724
Hi all, I have a problem with my PLC Program, and I was wondering if someone has a solution. If input X0 is 1, then outputs Y1,2,3,4,5,6,7 are...
1,503
I was asked to look at a job that involves resurrecting a piece of equipment that hasn't been used in ~8 years. It has a Mistubishi MELSEC...
3,744
