Melsecnet II problem.
cmulder
Nov 2002
Hi all,
I want to connect 2 Mitsubishi PLC's using Melsecnet II. I am using a A2AS-S1 CPU as master, and a Q2AS-S1 CPU as slave in this network. I want to send master addresses B0-BFF to slave addresses B800-B8FF, and I want to send slave addresses B0-BFF to master addresses B800-B8FF. I want to do exactly the same with data registers W0-WFF and W800-W8FF.
For some reason I can only send data one way. Depending upon the link settings I have set in the slave PLC I can send the data from slave to master, or vice versa. Therefore, I think the problem is in the slave PLC. Below I have printed the settings I am using for both the slave and the master.
Can somebody tell me how I need to setup the Melsecnet parameters?
P.S. I am using GX IEC Developer. If anyone wants to get the actual project I can send it to him/her via email. Please let me know...
Thanks in advance,
Caspar
Slave link settings (NET II (coax local)):
LB <-> B Head LB: 800 Head B: 0 Size: 100 hex
LW <-> W Head LW: 800 Head W: 0 Size: 100 hex
LX/LY <-> X/Y Head LX/LY: 000 Head X/Y: 0 Size: 800 hex
Master link settings (Melsec Net II mode):
Master to Slave Relay Area B: 0 to: FF
Master to Slave Register Area W: 0 to: FF
Watchdog timer for link: 2000 ms
Slave 1 settings (Melsecnet II station):
Local to master relay area B: 800 to: 8FF
Local to master register area W: 800 to: 8FF
Master Y: to local X range: to:
Master X: to local Y range: to:
We have three Mitsubishi A2N PLC connected through optical fiber cable. The Optical cable got damaged and we want to connect these PLC through...
1,677
Hello all, I have 7 Q series PLCs on a Melsec net/h network, Ladder Programming none of that fancy smancy ST stuff LOL :p. Were running the...
1,409
I have previously used a A1SJ71AP23Q card to bridge MelsecNet 2 to Q PLC. However, our local supplier told me that card is now obsolete. Has...
1,228
I currently am working on a project that involves adding CC-Link to an existing system that uses MELSECNET/H coax network. I have a small scale...
2,583
Hi guys, Good day! I just visited a plant wherein a Ship Unloader control is required to be rehabilitated. Existing PLC is Mitsubishi A Series...
1,535
