Memory Expansion for Compact Logix
demmons
Jan 2009
PA
87
Does Allen Bradley offer any way to increase memory in a Compact Logix 1769-L32E controller?
I need to make modifications in a processor which is already showing its estimated memory in the red zone.
The memory sizes on CompactLogix and ControlLogix 1756-L6x controllers is fixed.
If you cannot reclaim enough memory by deleting unused tags shrinking unused arrays, you need to get a 1769-L35E controller.
Changing controller types is super-simple; just select the new controller model in Controller Properties. Because you're staying in the 1769 Ethernet controller family, there will be no changes to the I/O structure.
Is there ANY way to expand the memory on a 1200? I have maxed out the memory and went as far as passing memory back and forth from working memory...
3,124
Calling out to the OMRON PLC fans, I am currently programming an Omron CJ2H-CPU66. I am needing to take a previous program from the larger CPU...
4,972
I am kind of new to GE products, but we have several in my area. I made a minor logic change and it verified good, but when I tried to download I...
43
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
82
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
369
