Message type from VB fins Gate Way
VBToCLK
Apr 2008
Surabaya
Hiiiiii every body....
I want get respons send command from VB fins gateway,but I have Try many Message type like: string, integer, double, word, variant, current --> its not valid.
Example: Text1.Text= FinsMsg1.receiveMessage(0,3,0,????)
receive message(NetID As Integer,NodeID As Integer,UnitID As Integer,Message Type)
Pleaseeeee................:(
We have just recently had an "outside" organisation upgrade our AB SLC PLC with a Controllogix. In doing so they have changed all of the messages...
1,807
We have an AB system that is connected to several CANbus networks via HMS gateways. A CAN message is comprised of upto eight, eight-bit bytes...
1,421
Hello I was trying to add a "Message" data file in a SLC500 PLC controller. I'm not seeing the Message as a "type" to select. How do I add the...
1,358
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
130
Developed a FactoryTalk SE program in English (Canada), finally setup the alarms and the message is reading "Message not defined for language...
49
