Micr0 1400 S6:44h error user define
Jeff23spl
Jan 2010
Canada
860
Hello
Do someone have experienced this error on a micrologix?
The help doc just say ''user define error'' as a description.:confused:
This bring a major fault to 2 identical plc panel at the same time.
Any help would be appreciated as i don't find anything on Google about it either
81
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
78
122
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
121
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
236
