MicroLogix 1100 String indexing
JeffKiper
Jun 2006
Indiana
2,461
Guys I know this has been talked about but I couldn't find it. I need to do a bunch of ASCII read and writes in a 1100. It doesn't support indirect or indexed addressing or STrings. So how do I do a work around on it?
I an sending a request and expecting a reply. I have about 30 to send so I need to don't really want to AWA and 30 ARD in this program. I also have to do string parsing so it is going to be ugly at best. Any ideas?
Any ideas?
Use a different PLC. 🍺
OK, more seriously, I think you are going to have to take a brute force approach.
One thing you could do for common operations such as parsing is to program the common operations in a subroutine that uses an intermediate tag. Then copy the string to the intermediate tag, call the subroutine, then copy intermediate results to final locations.
Scary when 2 people think so close. I just pasted 30 "SOR EQU N7:9 1 COP #ST10:1 #ST10:0 1 EOR " with an index of 1 on the EQU and ST10:x
I have a sub just for parsing. I added a little small 3 rungs that will verify if the string contains a Floating point. I then make that string into 2 INTs then to a Floating point.
Nothing about ASCII is pretty in a PLC. I guess that is why they are paying me to do it.
I will drop a copy of it in this thread after it is a little more polished.
Jeff
I don't know if you know this trick or not, if you do then never mind.
Take your SOR EQU N7:9 1 COP #ST10:1 #ST10:0 1 EOR and put it on the first row of an Excel spread sheet, one instruction or address per cell. On the second row put SOR EQU N7:9 2 COP #ST10:2 #ST10:0 1 EOR. Now highlight both rows, then hover over the lower right corner until your cursor changes to a + symbol. Click-drag down to row 30. Excel will fill down, automatically indexing the compare value and source address. Now copy it all out to a text editor such as notepad, delete the carriage returns and then copy and paste the lot into Logix 500. Presto, 30 nearly instant rungs.
Yes sir that is how I do most of my duplicate logic.
I use open office so highlighting both doesn't always work so I use CONCATENATE a lot I did a couple of robot communication jobs from a CLX. Before the guys got their program even talked about I gave them a I/O sheet copied from a UDT and Modifed in Open Office.
They asked how I did it so fast. I told them I am to lazy to work hard I work smart that leaves more time to play with my kids.
Thanks for taking the time to read this. From a string I am receiving vis RS232, I'm trying to convert that to a REAL or Floating Point. I need...
4,589
I am having a problem writing a string containing backslashes into an ST:9 file of an ML1100. I have the serial port set to ASCII and am sending...
2,865
I need to transfer string data from a MicroLogix 1100 to a ControlLogix 5000 L72 system. The string data resides in File ST9:0 on the MicroLogix...
3,792
I have a micrologix 1100 and I need to extract characters from a string data type and store the ascii values for each character in an integer type...
13,231
Does any one knows if micrologix 1100 would be a good choice to receive ascii string characters by Ethernet port and forward it using rs232 port...
5,506
