Micrologix 1100 w/Gocator 2030
mandyh92
May 2015
evansville in
I am new to PLC programming and ladder logic in general so this is my first application. My question would be when using the 1100, am I able drop the voltage on a output to 12v or will I need a resistor. the gocator documentation for the trigger states. Every Gocator sensor has a single optically-isolated input. To use this input without an external resistor,
supply 2.5 - 12 V to Pin 4 and GND to Pin 8. I am using a 24v powersupply and am able to read the plc and access programming mode just unsure what I need to complete this.
In general, yes you can use a voltage divider to obtain 12V from a 24 VDC output. you could use (2) 1K resistors in series from the output and tap the junction between them and end up with 12V referenced to ground.
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
139
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
544
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
198
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,197
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,415
