micrologix 1400 configuration with rslogix 500
sruthi
Jun 2010
Hyderabad
Can anyone help me out in configuration of micrologix 1400 with rs logix 500!!
I have a micrologix 1400 which i need to configure using rs logix.but am unable to find the selection of micrologix 1400 (1766-l32 bxba) in the rslogix 500.
I've opened rslogix 500 english and then clicked on file tab and then clicked on new tab where i usually configure ML1100 etc.I tried out similarly for the micrologix 1400 and unable to find the selection there.
Can i add micrologix 1100 in the options available for the selection of plc? or else how do i configure micrologix 1400 using rslogix?
pl. let me know the solution for the above.
I have a micrologix 1400 which i need to configure using rs logix.but am unable to find the selection of micrologix 1400 (1766-l32 vx) in the rslogix 500.
What version of RSLogix 500 are you using? You probably need to upgrade to newer version that includes the 1400 in its supported Processors.
Stu......
My version of rslogix 500 is - 7.30.10 (CPR 9).Does'nt this version support micrologix 1400?
which version of rslogix 500 is the latest?To which version should i upgrade?
can you give me the details pls.
V7.30 does not support the 1400, you need at least 8.10. From what I can tell, V8.30 is the latest release. If you have an AB Support Contract, you can request an update.
Stu....
Hello everyone.Am new in allen bradley configuration,i have a mini project to execute, i have wired my Micrologix 1400 for analog input signal of...
1,518
2,633
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
52
Hey all, first time poster here. I am wondering if anyone has tried using a Keyence SR-X300 barcode scanner to a Micrologix 1400. Keyence sent...
118
142
