Micrologix 1400 serie B
The "RSLogix Micro Starter Lite" software linked to by my colleague supports only the MicroLogix 1000 and MicroLogix 1100 controllers.
The MicroLogix 1400 controller requires a licensed, purchasable edition of RSLogix 500 software.
You can purchase it from your local Rockwell Automation distributor. In Veracruz, that's Risoul Automation.
thank you very much, did not know of a dealer near
i want to connect the plc allen bradley but says: autoconfiguration appears to have succeeded,however,rslinx has filed to identify the device
You get that error code if you have an old version of the RSLogix 500 software that does not support the newest controllers.
The problem may also be with your RS-232 converter.
What version (8.0 ? 9.0 ?) do you have of RSLogix 500 software ?
Please remember that the RSLogix Micro Lite does NOT work with the MicroLogix 1400 controller. If you downloaded it from the link earlier in the thread, you will not be able to use it with your MicroLogix 1400.
Please remember that the RSLogix Micro Lite does NOT work with the MicroLogix 1400 controller. If you downloaded it from the link earlier in the thread, you will not be able to use it with your MicroLogix 1400.[/QUOT
version is 8.0
73
122
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
235
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
338
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
702
