microview 2707
davo
Jan 2007
Adelaide
Hi, I am new to this. I have a AB microview 2707 that comunicates ok with a AB micrologix 1000, but i carnt get any communication with a pc. i have checked the wiring with the manuals and have also done a communications check with a dummy plug as the manual describes and this doesnt work either. I am using the AB 2707-np software. Does any one have any ideas. Thanks
This section shows how to download an application from a computer
running DPS software (Catalog Number 2707-NP, Version 5.0 or later).​
If you are using MicroView MDPS software (Catalog No. 2707-NP2,​
version 1.0 or later, refer to the MicroView Programming Manual​
(Publication Number 2707-PM002B-EN-P) for additional information.​
1.​
Apply power to the MicroView.
2.​
Place the MicroView into the Program Mode by performing
these steps:​
Press the [MODE] key to access the Mode Menu.
Press [3] to access Special Menu
Press [3] to enter the Program Mode.
Press [1] for uploading/downloading function.
The following message appears in the window of the​
MicroView.​
3.​
On your computer, move to the \DPS subdirectory where the
software resides. C:\DPS>​
Note:​
If you are using MicroView MDPS software (Catalog Number
2707-NP2) the default subdirectory is \MDPS.​
4.​
Type dps and press [Return] to start the program.
C:\DPS>​
dps
5.​
Specify whether you are using a color monitor. Enter Y or N.
You will not see this prompt if a monitor was specified during​
DPS installation.​
Programming Mode​
MENUto Exit
Hi Thanks for your reply. The only thing is that i bought the unit 2nd hand and their is an access code preventing me from entering the mode menue. i have tried the defult codes from the manual but they dont work. thanks.
Trying to find the software to upload the application of this interface. I'm going to a site tomorrow - the customer wants a backup for this...
1,194
The microview is made for the micrologix plcs, is it possible to use it with scl 5/03 serial port? and if yes, what is the cable pinout? thanks
1,507
Hi does any one know how to get past the limited access code which comes up when pushing the mode key on the microview. thankyou
2,074
Hi all, I recently purchased a machine that has/had 2MicroLogix 1000 PLC's with 2 MicroViewpanels. The previous owner stripped out one of the...
19
6,138
I have an A-B Microview (cat #2707-MVP232) connected to a Micrologix 1000 (cat #1761-L32 BWA). I purchased another one and want to set it up so it...
3,107
