Mitsubishi FX-80MR and HMI
o_man_ra23
Jan 2010
Australia
19
Gday all,
I am trying to connect a Red Lion G510 HMI touchscreen to a pair of Mitsubishi FX-80MR ES PLCs. I note that the Red Lion unit has 5 RS232/422/485 ports, and from what I can tell, the Mitsubishi runs an RS422 port on the front.
If I connect these up, will I then be able to also read the memory devices inside each PLC?
Kind regards,
Oman
I am not familiar with that PLC, so I am not sure if you will be able to multi-drop them off of the same port. If that PLC supports what they call Format 1 or 4, then you will be able to multi-drop using teh A/Q/FX driver. If they do not, then you will need to use 1 PLC per port and use the FX Point to Point driver.
With the FX Point to Point driver you can access the following memory areas in the PLC:
D (0-999) Data Register
M (0-4095) Interal Relay
S (0-1023) State Relay
X (0-255) Input
Y (0-255) Output
C (0-199) Counter Value
T (0-255) Timer Value
With the A/Q/FX driver you can access the following memory areas in the PLC.
X (0-1FFF) Input
Y (0-1FFF) Output
F (0-2047) Annunciator
M (0-9255) Internal Relay
B (0-1FFF) Link Relay
D (0-32767) Data Register
R (0-32767) File Register
W (0-657F) Link Register
TN (0-2047) Timer Current Value
TS (0-2047) Timer Contact
TC (0- 2047) Timer Coil
CN (0-1023) Counter Current Value
CS (0-1023) Counter Contact
CC (0-1023) Counter Coil
Here is a link to our Mitsubishi information sheets and cable diagrams: http://www.redlion.net/Support/Downloads/DeviceDrivers/G3/Mitsubishi.html
Regards,
Dan
Thanks for the replies fellas.
Dan, I am looking to run a separate cable to each PLC, so using 2 ports up. Thanks for the confirmation, I can now go back and work out how long it will take me.
Dave, thanks for the link. Should give me a good start on things.
Cheers, Owen
I've worked on one Mitsubishi PLC in the past 40 years. Now, it looks like I get to tackle another one...using GX-WORKS3-C1 software which I...
964
I have been asked to work on a Mitsubishi Melsec FX2N-80MR PLC but have no experience with Mitsubishi at all. The hope is to get online to find...
1,350
We received a cell that has a MELSEC Mitsubishi FX 2N-80MR PLC installed. We need to access the PLC program for troubleshooting and additional...
1,985
Dear frnds......... I m facing a problem in my project in mitsubishi plc fx2n 80mr. i want to back up my relay output . i mean i want them active...
4,757
Hopefully someone can offer words of advice. I've got a Mitsubishi FX2N-80MR to suck the program out of. Never used one before. I have a USB to...
1,410
