mitsubishi fx2n64 problem
jalil
Jun 2006
jeddah
HI ALL
I have fx2n64 plc with scada monitoring system. Recently I cannot get communication from PLC to scada via rs232 port(from PLC rs 232 port to pc COM port).but I can read and write to plc via sc 09 cable with Gx developer. My only problem with plc RS232 port. I changed RS 232 module ,not work, my scada computer and protocol is ok. Please
Suggest me in this matter.
Good luck
jalil
Hi jalilWhen communicating withe Mitsu FX'series.
The protocol for the PLC/PC must be:
Baudrate: 9600
Parity: Even
Databits: 7
Stopbits: 1
Are your application set up for that?
Dariusch
If you have not changed the program then you either have another duff 232 interface, bad connection with interface & plc or maybe the plc is not talking to the 232 card.
have you tried using 232 via gx to the 232 port.
Are you sure your scada pc is talking to the PLC?
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
39
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
37
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
101
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
76
