Mitsubishi FX2NC PLC
SEJPA
Dec 2013
San Diego
I have a remote input terminal block (FX-16E-TB/UL) that appears to have failed. Can I replace this block with like kind without PLC configuration?
I have actually never seen one of those before, so I looked it up.
I would say, seeing as it's either an input or output extension it would be ok to replace it without altering any parameters or the program. They will already be addressed in the program.
Dear all I am trying to get the decimal value like 1.2 or 2.5 into Mitsubishi FX2N PLC (like D40) from HMI software NI Lookout6.2 for...
5,750
Anybody ever see a problem where the error LED turns on when you plug in the SC-09 programming cable? I can't connect to the PLC either. If I...
3,430
I have a project where the FX2NC looks like the ideal solution. However, I need to connect the a pc (for programming) and a touchscreen at the...
3,759
Hi, How to get data from multiple Mitsubishi Q03UDVCPU into master PLC Q03UDVCPU through QJ71E71-100 ?
32
So the customer purchased a Mitsubishi drive, in the same project for a different pump they got an ABB drive, was literally whatever they could...
57
