Mitsubishi Fx2nc
thierry2003
Oct 2003
70
I have a project where the FX2NC looks like the ideal solution.
However, I need to connect the a pc (for programming) and a touchscreen at the same time. What are my options to provide an extra programming port?
I've looked into using the FX2NC-232 ADP or the FX-BOX-ET-10T (ethernet interface) but I am not sure if it would work.
Anyone knows?
To bad those E-terminals are so expensive.
I love their functionality but I think I try something like the G3 series from Red Lion.
Anyway, are you sure I can program the PLC using the 232 ADP?
So instead of the standard programming cable I'll use a standard RS 232 cable, right?
Or will he ethernet module work? Documentation is really limited on that subject....
I've never used one, so I can't be certain. The manual states that it can be used "to connect a programming tool", so you should be able use a standard cable. The port is wired as a DTE device (just like your computer), so you'll need a null-modem cable.
If you don't already have it, the manual for the FX2N-232-BD is available HERE. It has good connection diagrams.
beerchug
-Eric
I've used RS232 card with FX1N (FX1N-232-BD) and it works just fine with all PLC programming functions.
And it was much cheapper that SC09 ;)
FX2N should be the same
Thanks for the answers.
I'll check again on pricing of the Mitsubishi and Beijers terminals and use one of those if the price is right.
If not the 232 will be used.
I always have an extra 232 port on hand for those Fx.
They are real cheap and usefull when having to work with HMI AND PLC at the same time.
I would have both programming softweare running and can modify the two simultaneously.
(here they cost 65$ canadian which comes to $4.99 US):)
After my program is finish I just pull it out and keep it.
I have a remote input terminal block (FX-16E-TB/UL) that appears to have failed. Can I replace this block with like kind without PLC configuration?
1,553
Dear all I am trying to get the decimal value like 1.2 or 2.5 into Mitsubishi FX2N PLC (like D40) from HMI software NI Lookout6.2 for...
5,729
Anybody ever see a problem where the error LED turns on when you plug in the SC-09 programming cable? I can't connect to the PLC either. If I...
3,417
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
