Mitsubishi FX3u modbus TCP/IP
For Modbus you should use FX3u-ENET-502 instead of FX3u-ENET. First one can access to port 502 which is the standard Modbus port. You can even use FX3u-ENET, but then you have to do some tweaking...
FX-Configurator EN is configuration tool. You can do it also through program but it is to complicated...
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
172
I am trying to configure a Modbus connection to a Mitsubishi FX3UC PLC via a FX3U-232ADP module and I have fell at the first hurdle. The...
1,709
Hi! I have PLC (FX3U with FX3U-485ADP-MB) wich is connected to AV38 (device with display, which supports modbus protocol) via modbus RTU. It was...
3,839
Hello everyone; I have Mitsubishi PLC FX3U 32M in hydropower plant governor, an error message popped up when a technician was working on an...
383
hmi keeps saying "insufficient sensor failed" after the machine runs for 60 seconds. its a fx3u-48m PLC. The plc is not giving any errors or...
2,277
