Mitsubishi HMI
daniel_yang
Jun 2023
windsor
Hi, Anyone know Mitsubishi PLC ? I have a A960GOT HMI. When I power it up,
It shows "system is wired incorrectly! please change phase sequence!" it is my first time to work with mitsubishi production. I checked the power is 120Vac. I do not know what should I do next step. I am looking forward to your answer asap. Thanks
I would assume it is referring to the comms cable rather than the power supply as it must have powered up without releasing any magic smoke to display that message.
The manual shows several different RS232 configurations depending on model and usage.
Thank for your answer. I did check communication cable rs422. SDA;SDB;RDA;RDB. they are good connection. the PLC cpu is A2Ascpu. I do not know how to make HMI displays normally first. I am looking for hlep!
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
162
Hi anyone meet the situation like it I posted. really need hlep!!! Need the HMI displays. I am looking for your answer asap.
281
Hello Everyone, I am hoping someone can point me in the right direction. I have a Mitsubishi PLC FX3u connected to an old ProFace GP2500 HMI...
1,576
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,309
The PLC code calculates oil flow rate and outputs it on D420. It is represented on the HMI as a vertical bar. Problem is that the operator says...
33
4,934
