Mitsubishi OPC network
Wouter T
Mar 2013
Antwerp
Hello,
I'm doing an internship at a company to finish my current education, I haven't worked with mitsubishi plcs before but it seems pretty straight forward.
Now I want to make create an OPC network so I can log data from different PLCs on the plant.
I've never had to do hardware setups like this, I have plenty of programming and software OPC experience but I've always had an existing network to start with.
Now I'm wondering what would be the easiest and cheapest way to go about this. Any input is appreciated.
CPU list:
(8) A2ASCPU-S1
(3) A2ASCPU
(1) A2ACPU-S30
(1) A3ACPUR21
It appears all cpus but one have a A1SJ71AR21 data link module attached to it. There are only two cpus that don't. I also found a network topolgie sketch, the cpus appear to be connected to the network. They appear to be connected in a ring.
Is there any way I can test this without buying OPC software before I know it'll work? Any trials or freeware?
Just wondering if anybody out there is using the Mitsubishi iQR OPC UA Module (RD81OPC96)? And if so are you using it with labels? Or direct...
1,127
Hi everyone. i am about to start a project using for the first time mitsubishi's MCWorks64. I read the documentation and it includes OPC server...
2,323
Hi, In a project I have four Progressive Pressing Machine. Each machine with different PLC like Mitsubishi 'Q00UCPU' with...
3,054
Well i have a fx1n mitsubishi plc and the thing is that i'd like to make a communication between the plc and Matlab, so Matlab can read and manage...
1,902
Hi All, I'm using Kepware OPC server to set up communications between a Mitsubishi PLC and wonderware Application server. Every time we deploy...
3,743
