Mitsubishi SP Para Error
MattColeman
Sep 2013
Home
Hi Team,
I have a Q03UDVCPU and I'm trying to add a QJ71C24N communications card.
I keep getting a Error 3300 Sp.Para Error I/O number in intelligent function module parameter set on peripherals differs from actual I/O number error.
When I look at the I/O assignment , the card is located in slot 4 (xy 0040)
When I look in the property of the card, mounted slot 4 (xy 0040)
Is there somewhere else I need to look?
Is there a particular process required when downloading parameters and code to ensure correct configuration is written?
Kind Regards
Matt C
First of all, what IDE are you using GX Developer GXWorks2 etc.
If GXWorks2 then configure it under intelligent function module.
see pic, I cannot help anymore than this as it was some years ago when I did one & that was on GXIEC Developer IDE on a Q series & I do not have the hardware anymore.
If the above does not work...
Is this a brand new CPU or an additional module being added?
If you are happy with your parameter settings, you can try a Standard ROM format then re-download your parameter file.
Regards
Daniel
Hey Guys,
Thanks very much for the feedback, your recommendations above are the actions I was doing. I have sourced further support from Mitsubishi and other system integrators and I have been unsuccessful. At this point I will advise the client the look at other options.
Kind Regards
Matt C
The only things I can think of are:
The I/O address for the card is incorrect for example 16/32, (intelligent module), The I/O numbers are wrong or pass over the boundary of other slots (normally this is automatic unless you force it).
Post screen shots of the PLC Parameters (I/O config) & the error message & you have not stated what IDE you are using i.e. GXDeveloper, GXIEC, GXWorks.
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
47
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
41
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
106
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
77
