ML 1100 LCD Not changing
Hojland
Oct 2006
Langå
203
I have a Ml1100 and have prg the LCD, but i can´t get the lcd to update the nummber from my program. It just stays on 3 even that the nummerber is different. When i press the esc key it updates....help
Normally, the ESC key moves focus out of the current menu and back to the previous menu, or in some cases it cancels an entry or change.
What keys on the LCD did you tell your program to use? It sounds like you used the ESC key as a program input key. Many PLCs with LCD displays allow defining the LCD display buttons ESC, OK, ^, v, <, and > as any program switch or pushbutton. It sounds like you need to read Chapter 5 in the MicroLogix 1100 User Manual, page 5-128, User Defined LCD Screen.
Has anyone had success programming the LCD screen on the 1100? I've been working with this for awhile and have discovered that if you're on a...
5,410
Has anyone used the MicroLogix 1100 to set timer, counter and other functional values? I got a project handed to me this week and the 1100 has...
6,005
I have a program that has 2 LCD Displays as follows. The first display does not use the User input function. It displays level and temp etc. In...
5,602
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
151
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
550
