MLGX 1400 and REd Lion Data Station Plus
JohnW
Mar 2004
Cornwall
487
Has anyone used a Red Lion data station plus to talk to a micrologix 1400? If so, did it work OK or are there any issues I need to be aware of?
The Micrologix 1100 pretty much has the same communications ports as the 1400 and I have used them very successfully with the Data Station
I have a Micrologix 1100 with a locked program that I'm wondering if I will be able to download if I need to replace the PLC? I've only ever...
2,664
63
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
57
121
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
119
