MLX DF-1 problem
HJTRBO
Jul 2008
Melbourne
618
Hello,
I had a problem today where I Linx couldn't auto configure to the ML 1100 I was working on. Luckily I could go in through ethernet!
Any how, I had the error o4X come up, this has been covered before and for the life of me I cant seem to find it using the forum search. If any one would be kind enough who has a memory better than mine be able to point me in the right direction?
If some of you would be prepared to go over it again I have RS Linx Gateway 2.54, RS Logix V8.10, PC to MLX cable. I was unable to use auto configure. It would hang on "auto configure initialising" When I tried 'who active go online I had a 'error 04x' come up.
Many thanks.
Tell us how the port is configured. Look at your offline file.
Tell us what cable you are using (cat. Number)
Hi All, I wrote some code for a small hydro scheme a couple of months ago. Part of the project was to read data from a grid analyser via RS232...
1,652
Hey Guys, I am struggling to read data from a "JUMO" make controller using modbus RTU with MLX1400. The communication between the devices has...
18
5,109
Is it possible to create MSG in SLC to read data from a mircologix 1000 via serial DF1? I have Micrologix 1000 and SLC5/04, the serial port on...
1,802
HELLO BOYS, I HAVE AN INTERROGANT, HOW CAN I MIGRATE A PROGRAM FROM A PLC MICROLOGIX 1500 TO A PLC 1400:beerchug:
1,636
Newbie question here, I have been trying to setup a Ethernet/IP network consisting of 3 AB Micrologix 1400 plc's, one Idec HG4G-CJT22MF-B OI, and...
3,340
