Modbus TCP/IP communication Modicon M340 to GE PAC RX3i
ALI.R
Apr 2013
New Westminster
We need to setup Modbus TCP/IP communication between "BMX NOE 0110" (Modicon M340 module) and "IC695ETM001" (GE PAC RX3i module).
Manuals say both are supporting conformance class 0 FC 3 and 16 (multiple register read/write), but I want to see if anybody has done that before (make sure there is no grief)?
Thanks alot,
I need to setup Modbus TCP/IP communication between "BMX NOC 0301" (Modicon M580 module) and "IC695ETM001" (GE PAC RX3i module). Anyone as any information or a sample configuration/logic of how to do this? I do not have the hardware as yet to test the link.
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
380
Hi, i cant establish communication between fatek plc with an energy meter, both capable for modbus tcp, i did with modscan but fatek plc does not...
208
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
432
CR3000 HMI ModBus TCP/IP Master has gotten erratic after increasing block size to 24 at DA70A in Protocol 1. What should a practical guide be for...
586
Good day Programmers I have a RSTi-EP CPE100 Standalone Controller from Emerson as well as a STXMBE001 (MODBUS TCP/IP) as a Modbus communication...
670
