monitoring valves on press
panic mode
May 2003
Toronto, Canada
1,963
Hi everyone,
I am about to get involved for the first time with the controls for the press. In few days I should have my press standard (CSA Z142 if I remember). By then I would like to get some basic info from you. In particular I'm interested to learn about monitoring of the valves.
I've found out that valves used for press applications have little appendix consising of 2+1 contacts. How to use those?
I guess they would have to go to monitoring safety relay which then controls ... what?
Regards,
Greetings again:
Press control staarted getting difficult so we started using press control packages. Our first was Allen Bradley which was very touchy. The 2 resolvers required needed to be kept in sync or the press would shut down. They were to be mounted on opposite ends of the crankshaft but pneumatic clutch controls interfered most of the time. Also dual processors were required. We finally settled on the wintriss control.
Wintriss
I hope thjis helps.
thank you... just a week or two ago there was CSA seminar in
our neighbourhood about the topic but I didn't attend since
I didn't know about it and I wasn't avare of the project.
Now I'm trying to digout as much as I can... :rolleyes:
Any thoughts on this one? I'm designing the controls for an operator-loaded, light-guard protected hydro-pneumatic press (pneum approach...
4,393
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
68
Our punch press has a SLC500 with HELM weight module (HM-604-WM) for tonnage monitoring. The operator enters the weight range on the HMI, which is...
210
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
126
Good day, we have 15 analog inputs, we need to log the data in excel and monitor these values through web browser. We're planning to go with Delta...
133
