motor control
shanmu_gam
Mar 2007
22
hiii every one,
I have one low power 150W single phase motor and need to be controlled its speed.Is there any way of controlling its speed without inverter drive.I am not using any Plc for my application.pls advise me in this case.
Kid Blue:
The description says: "This is unsuitable for use on inductive loads."
Motor = inductive load.
Have you tried using this electronic regulator on a motor load? Perhaps it might work with a very small 150 watt motor.
Oops! :sick: Didn't check the spec fully! I have used that principle before (but rolled my own triggering cct) - and it seemed to work fine (small drill motors etc). The only thing i added was a snubber cct across the load....
I was looking for a link to the module i had come across before but couldn't find it. I know they're readily available for this exact application.
Sorry for the duff data!! :whistle:
Don't be sorry, because it may still work. If you did it before with a drill, then that's good enough for me. The circuit in the link shows connecting the phase regulator to a triac, and the triac does the switching of the voltage to the motor, so for a small motor, I can see that it just might do the trick.
Drill motors from power tools and other brush type motors are not considered inductive loads due to their rather low selfinductance(?). Phase shift does not occur, so triac voltage regulators work really well. And their speed can be easily controlled by changing the applied voltage.
It's a whole other issue with asynchronous (PSC) motors. Their speed is not proportional to the applied voltage: The frequency determines their speed. However for some applications (with exponentially changing loads) like fans and blowers, a voltage regulator does work. For all other load types, it does not.
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
238
Hey there, I just have a motor related question. I am using a 90V DC motor (https://www.motion.com/products/sku/03889770) and am controlling it...
241
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
746
I'm controlling an Applied Motion HW23-601D using a Leadshine EM542S connected to a 2080-LC50-48QBB, using CCW, and experiencing some weird...
616
This is my first time doing any sort of motor controls with PLCs so I am looking for some help determining what kind of equipment I will even...
1,231
