mpi
sourena
Sep 2007
WA
conecting online to the plc in set pg/pc interface needes mpi adress.
how can i finde the mpi adress?
can i give any address between 1 to 30 or should be same address that has programed?
Default is/was:
PG : 0
HMI : 1
PLC : 2
Best to make it 0 that way in 99.9999% of the cases it will be correct.
Hi I Have new CU320 Module (6sl3040-0MA00-0AA01) for sinamis G150. i want to download Backup config. of old CU320 to new Module with PC Adapter...
539
I have a customer that wants us to use a S7-400 PLC. I don't get into Siemens too often (unless I have to). This machine doesn't do much and...
5,031
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,482
Hello guys, I have upgraded the old 318-2aj00-0ab0 cpu to a 317-1ak14-0ab0. After an upgrade there seems to be a communication issue to a HMI...
1,874
Hello automation experts. Do you have any experience with cheaper USB/DP adapters, such as Amsamotion? I would use it occasionaly, mainly for...
1,679
