Need help with small program
Ayejay
Dec 2023
Townsville
Hi all,
I’m new to programming and want to write a simple routine.
Push start button, turns on sensor.
2 second delay before anymore logic read.
When sensor is triggered alarm 1 sounds for 5 seconds then alarm 2
Sounds for 5 seconds.
Then reset and wait for start button.
This is what I have done but not quite right
IF _IO_EM_DI_00 THEN
_IO_EM_DO_00 := TRUE;
TIMER_DELAY(IN := TRUE);
END_IF;
IF TIMER_DELAY.Q THEN
IF _IO_EM_DI_01 THEN
_IO_EM_DO_01 := TRUE;
TIMER_ALARM1(IN := _IO_EM_DO_01);
END_IF;
IF TIMER_ALARM1.Q THEN
_IO_EM_DO_01 := FALSE;
_IO_EM_DO_02 := TRUE;
TIMER_ALARM2(IN := _IO_EM_DO_02);
END_IF;
IF TIMER_ALARM2.Q THEN
_IO_EM_DO_02 := FALSE;
RESETSYSTEM := TRUE;
END_IF;
IF RESETSYSTEM THEN
_IO_EM_DO_00 := FALSE;
END_IF;
END_IF;
Read the red statements in order: (1); (2); (3); (4); (5).
if _io_em_di_00 then
_io_em_do_00 := true;
timer_delay(in := true);
end_if;
if timer_delay.q then
if _io_em_di_01 then
_io_em_do_01 := true;
timer_alarm1(in := _io_em_do_01); <= (3) which will reset timer_alarm1, and timer_alarm1 value will be 0
end_if;
if timer_alarm1.q then <= (1) when timer_alarm1.q becomes 1,
<= (4) so this IF will no longer evaluate to True
_io_em_do_01 := false; <= (2) _io_em_do_01 will be assigned a value of 0
_io_em_do_02 := true;
timer_alarm2(in := _io_em_do_02); <= (5) and timer_alarm2 will no longer be evaluated and will never expire
end_if;
if timer_alarm2.q then
_io_em_do_02 := false;
resetsystem := true;
end_if;
if resetsystem then
_io_em_do_00 := false;
end_if;
end_if;
Hello all, I need help in a small plc program in Allen Bradley plc. Need to generate a 1 second pulse on every ON and OFF of a bit. Suppose for...
2,111
Dear sir. i have one Automation Direct hmi, if you have the CMORE Programming software,i will send you .eap file in email, can you please...
2,443
Hi guys we are constructing a small production line 5 km away from our factory that includes hydrolic presses and small machines. We want to get...
3,954
28
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
