New control enclosure for machine
Klincker
Jun 2018
Arkansas
So I am new here at my place of work and noticed that some of the veterans on the dayshift side are making an electrical enclosure. I took a look inside and was quite shocked with the way this was done... Should this be completely illegal to install on a plant floor or am I just over reacting. What would you NEMA rate this box also?
Maybe one more time??
I hope it worked with the attachment this time. Says its on there and then doesn't post out to the thread. If it doesn't work this time I guess i'll just have to go to the practice section lol
You know that you have to put your images in an image hosting site, right? You can’t post images from your computer.
If you did use a hosting site, it must not be allowing remote calls. Some don’t. Pick another site.
You can certainly attach images directly. They just need to be under 300kb. Maybe try resizing / compressing first.
I'm intrigued to see this image now!
We've had a number of design discussions and done some extensive testing on enclosure heating/cooling solutions for various panel builds...
705
Hello! What are your thoughts on a packaged MCC solution such as Allen-Bradley's Centerline series which can contain any combination of starter...
1,797
So the customer purchased a Mitsubishi drive, in the same project for a different pump they got an ABB drive, was literally whatever they could...
71
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
148
Hi all, I am upgrading a couple of 2094-BC01-M01 servos with 2198-H015-ERS. The original code uses MSG instructions to control (release, engage...
92
