O/T Electric Lawnmowers
gbradley
Apr 2002
Corona, Ca.
1,637
šŸ¤·
After 8 years my trusty Craftsman has finally bitten the dust.
So I am in the market for a new lawnmower.
I am considering purchasing a corded Electric.
The lawn in back is only about 30' x 60', and the front is less than half that size.
Anybody have experience with Electric Mowers?
I know this is not PLC related, but I trust the opinions expressed here.
George
Why not stay with the trusted Craftsman . I had a sears gas mower that lasted for 22 years. The motor was still going strong ( no smoke) but the wheels finally fell off because they finally rusted out.
I just got a push mower.
It's really not bad at all, you don't have to deal with maintenance, gas, cord, etc. Just spray some oil on it once every few years.
Do it!
Well it is smoking a little bit. I would rather put the money that I would have to spend to repair all of the things that are wrong into a new unit.
I was still using the mower until the other day when the pull starter mechanism broke. It's a plastic housing with springy clips that flew all over the place when I took it off.
I may end up buying another Briggs & Stratton powered mower, after all this thing was ridden hard and put away wet as they say.
I think that the electric mower may be a little bit better environmentally speaking.
šŸ¤·
I know this is not PLC related, but I trust the opinions expressed here. Thanks George
George
Had one - underpowered but it was an "orange box special" back in 73. Would do again with beefier motor.
What design is your present unit reel or rotary?
What would it take do you think to convert present unit to electric using 1.5 to 2 HP electric? I am a tinker artist so I would do the conversion.
Cord is a pain admittedly.
I think much of it depends on how often you mow. If weekly it would do fine - monthly better be careful you may burn the motor if you stall it or continually try making it cut hay.
Better for environment OH YES but I will not get into that it is your conscious and value set and of course your bucks.
Dan Bentler
The human-powered push mower is even more environmentally friendly. In addition, the operation is a mild cardio workout. Assuming a one foot wide mower, you're looking at less than a half mile walk. The resistance offered by the mower makes it the equivalent of a moderate grade. The longer you wait between mowings, the steeper the grade.
I had one for a while - wouldn't want another - too easy to run over the cord. Did that twice.
Sure, it's no big deal to repair the cord, but your dead in your tracks till you do.
I'm a wee bit anal about my cords, so unwinding and rewinding was enough of a pain, I quickly learned to dislike that, too.
My gas mower starts on the first pull, never kicks out in the middle of a run (provided, of course, I am not too lazy to fill it before beginning), and stores away immediately.
Electric (n)
Gas (y)
My $0.02
Steve
That's just crazy talk. ;-)
I did that back in the 60's.
Sorry, but I'm not going back there.
I remember as a kid forgetting to mow for a week.
Push, pull back, push, pull back ad infinitum.
Said with a chuckle
Yeah but a hand push reel would give you incentive to mow weekly. Did that in 60's also so I had the tall grass incentie plus my MOM to mow weekly.
Dan Bentler
I've had my electric mower for 1 1/2 years; never ran over the cord.
It can be a pain to throw the cord back and forth while mowing; but you get the hang of it quickly. I like not having to keep a gas can anymore.
I have had a Honda Electric (cord) mower for 10 years, before that my brother had it for around 5 years and before that my aunt had it for who knows how long. I can't kill the thing!
The only thing I've done is sharpened the blade and replaced the bag.
I have my cord routine down to a science now but it did take some getting used to... and I'm not that anal about the cord winding. Knock on wood I've never cut the cord running over it; I do keep the cut height at the max height so that helps.
Before that I was a religious push mower but once kids came around and I couldn't be sure to get it every week in the summer, and my brother was giving the electric away for free I switched.
Funny, I just realized I have never paid for a lawn mower as the push mower was left by the people we bought the house from and my brother gave me the electric. Maybe if the electric dies I buy a sheep šŸ™ƒ.
Rs485 module then 2 wire belden 9841, modbus network picking up electric meters. Does this need to be wired as a ring or a radial? Thankyou
91
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
228
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
242
Hi Friends, I am facing a problem with encoder adjustment in Sew Electric Cylinder CMS71L. encoder using is Sick Hiperface Drive is MOVIDRIVE...
17
801
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
122
