O/T Windows: Figuring Out Which Port
gbradley
Apr 2002
Corona, Ca.
1,637
Sometimes when I fire up RSLinx, I get a port conflict.
I have to go through these 6 steps in order to figure out which COM port the USB 1747-UIC is on....
(1)Click Start Menu
(2)Right click on My Computer
(3)Select Properties
(4)Select Hardware Tab
(5)Click Device manager
(6)Expand ports to see which port the 1747-UIC has chosen
Once I know this, I can go back and configure the RS-232 DF1 Device.
Anybody know of a quicker way to get there?
Thanks Lionel, (y)
I thought that I should just make a shortcut and put it on the desktop, but I didn't really know what the Device manager was called or the file extension. :confused:
Now I know "devmgmt.msc"
George
Another solution. Allways use the same usb port. Set it up in device manager as comm1. Works for me. Dont have to go to device manager all the time
...and for port numbers for unconnected devices
If you want to check the assignment of all port numbers, even for devices which aren't currently connected to the PC, try the following at the command prompt or in a batch file;
cd c:\
set devmgr_show_nonpresent_devices=1
cd c:\windows\system32
start devmgmt.msc
This will open the Device Manager window, then from the "view" pull-down menu select "Show hidden devices".
You will then be able to see all the COM ports that have been configured and what driver is associated with them.
I have found this very useful when re-assigning port numbers for USB/RS232 converters (and have to run old DOS programs that can only use COM port 1 to 4).
Regards
Alastair
You might be interested in this:
http://bayden.com/SlickRun/
Basically it's like the Run command bar in windows except you can create mini-macros instead of typing in the whole command line parameters.
It's very minimal and not intrusive.
Great for when the boss is walking over ... ;-), not that I've ever been told not to plctalk at work....
That's funny, I always used Win+M for "Minimize", but I see that Win+D works better because it toggles back and forth.
Thanks Nathan
I'm quite embarrassed to say that I only have a rudimentary understanding of IP addresses. I have a PanelView Component 2711C-K3M HMI...
2,683
Hi I am trying to configure a TSX FP 20 PCMCIA fipway adapter to run on a laptop running windows 2000. I have installed the driver and the card...
3,809
Hi everyone, I have an issue with installation of Studio 5000 33.00.02 DVD Media disc 2 with View Designer on Windows 11. After installation...
117
Hello all, Hope everyone enjoying their weekend. I just recently bought a laptop to upgrade my old one with i3 its getting slow on me. But when i...
431
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
344
