old modicon PC-A984-130
srraja
Mar 2004
i have an old modicon of following configuration
main rack
CPU: PC-A984-130 (two slots space)
power supply: (one slot space)
input module (DEP208)
input mosule (DEP208)
expension rack
output module BDAP218
the PLC was stored with battery disconnected
i have modsoft 2.11/2.21 (dos version)
can any one guide me through steps for configuring the plc for simple control applications. i am new to modicon but familier with ladderdiagram and use other brands
i have plc connected with my notebook which have modsoft
1-2-3 instructions for Modsoft
First you go to the off-line mode and create a new program.
Second you need to configure (key F5) your system, Overview (F3)lets you chose your PLC type, you can use the defaults for everything else. I/O Map (F4) is used to locate your I/O (? is used to open the pick list of available cards) and assign addresses.
Third after developing your program, go back to the main page and use the Transfer option (File to PLC) to download the program.
don't forget 'dim awareness'
I remember difficulties with a 'dim awareness' message
for the initial download, but, don't remember if it
was on a 984 or not.
The Modicon help line or the local distributor (or the eBay
seller) should be able to help you through it, if you see it.
Dim Awarness
All Modicon processors generate a Dim Awarness error on all new power ups and when recovering from a loss of memory caused by low/no battery.
The recovery is very simple, download a correct configuration to the processor.
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
305
Hello, I have some Modicon 884 files that I need printed out. I would rather not buy a whole software package, all I need is the print out of a...
1,913
Hi I have a Modicon Quantum 540 14A CPU that evertime I cycle power to it, it seems to lose the software (at least thats what the Modicon tech...
2,176
Dear All, i have redundant quantom from modicon. -The application program was worked very good ,Before,i changed the resolution of RTD module to...
1,816
Need a cheap source to read some old modicon programs. I'm told they were created with Modicon Modsoft lite. Program extenstions are as...
6,274
