Omron CJ1M-CPU11-ETN help.
Kroz
Mar 2003
I just got a new Omron CJ1M-CPU11-ETN with ethernet capability hence the ETN. I am trying to set up the ethernet with the manual and am having problems. Can someone give me the steps to setting this using CX-Programmer and be able to see the PLC with a web browser?
What information do you want to be able to see via the web browser?
The IP address is on the side of the CPU module, side were the I/O modules plug in.
You can set up the ethernet information using CX-Programmer. Depending on what version of CX-P you have can make a difference in how you will need to procede. Basically you need to use the IO table and set up the Ethernet "module". CX-Programmer sees the "ETN" as an Ethernet module in the first IO position. There is a manual #W441 that gives information on the CJ1M-1_ETN processors.
Hope this will help.
I would like to monitor inputs and outputs through a web browser. I am not sure of anything else because I don't know the possibilites.
I was able to figure out how to assign the ethernet card an ip address. It was a little harder to figure out that the rotary switches on the front of the card, which control the Node address, have to be set to the last two digits of the ip address. It also has to be in hex. For example, the ip I am using is 192.168.2.28. On the card, Node X16-1 is set to 1 and Node X16-2 is set to C.
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
331
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
207
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
201
Hello, I have PLC Omron CJ1M/CPU11, the problem is whenever i connect the PLC to my PC (laptop) via serial port and try to go direct...
2,511
Hey, new to Omron. I have a CJ1M CPU11 PLC that I need to connect to and backup. When I look up Omron programming software, I find three different...
1,701
