omron ns8 to mitsibishi problems
mattyp
Nov 2011
carlow
HI everybody, this is my first post on here,
I have 2 Omron NS8 TV00 V2 hmi's that i need to connect to a pair of mitsubishi plc's it is my first time trying to communicate between omron and mitsubishi and i am not too sure what exactly i need. first project is to connect to an FX3g-14M i have selected melsec f in the comms settings of CX designer but i dont know the comm speed data bits etc. also what cable / converters do i need.
the next one i'm really stumped on i want to connect to a Q00 cpu and the only info i could get so far is that there is no protocol to connect to system Q but it ''might'' work using a serial communications card on the rack.
Apologies if the answers to either of these questions are obvious but I am relatively new to this.
If anybody has done this before I would GREATLY appreciate some info.
thanks in advance....
The version of your application is shown at the bottom right of the application screen as shown:
You can change this by clicking on 'Tools', 'Convert', 'Version' and then select the newest version you have over 6.0. I have tested with Version 8.0.
In the communications tab we can see the default
setting.Highlight 'serialA' then click 'delete host'
Accept the dialog box question to save the application, and then click on 'serialA' again. Then select 'MC Protocol' as your choice:
Hi Liam
Im away until the weekend i'll try that when i get back, thanks a million. oh and i was using version 8.4
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
912
I'm working with a Dry Cleaning facility. We have 2 (two) Dry Cleaning machines that use Omron HMI model NS8-TV00-V2. Three days ago, one of our...
1,735
Hi all, I have a customer that has a series of around 15 Omron CJ1M PLC's, each connected to an Omron NS8 HMI via an ETN21 module. The PLC and...
2,937
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,780
I have an Omron NS8-TV01B-V2 that will not start up. Has an error warning. I tried to create a program in CS-Design and down load to a flash card...
3,728
