OPC Alarms & Events SIMATIC NET 8.0 C#.NET
awnet
Jun 2007
Viareggio
44
Hi All,
I have a question about OPC Alarm & Event with SIMATIC NET
V8.0.
I have a SCADA C#.NET and I want to visualize the alarms from a PLC CPU 300.
To get help for my project,I found and used this document "26548467_OPC_AE_DOKU_V10_e.pdf" from Siemens.
I tested plc and pc .net C# application , but the problem is that I cannot modify the text message of the alarm. So I can see only ALARM1, ALARM2, etc.. instead for example "ALM1 High Temperature Water".
This document is for siamtic net v6.4 in particular. It tells to use scores7.msg file to configure block related message.
I used sfc17 like the document shows.
The question is I cannot find the scores7.msg in the s7bin folder of the SIMATIC NET 8.0 directory file like the document shows and I cannot browse the opcsimaticnet in opc scout v10.
What do I mistake ? o_O
Thank you for help
Hi All :bow:, I'm using the new OPC UA server in my MS Visual Studio VB.NET SCADA aplication and I would manage also alarms and events from PLC...
2,010
I am currently working on a project(not PLC based but Access Control) where I need to get data from an OPC Alarm and Event server into Excel, as I...
4,937
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
48
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
276
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
229
