OPC and Delphi
Steve Wiebe
Jul 2002
68
Hello All,
A member (JesperMP) suggested uploading a sample of how to use OPC and Delphi to build a simple HMI program.
See http://www.plctalk.net/qanda/showthread.php?t=52946&page=2
I've uploaded 4 examples to the HMI_Files area:
- A basic example using standard windows components to display PLC data,
- A bit more advanced sample using some freeware components to display data,
- An eample of how to use a marquee from EZAutomation.Net, and
- A report generator with preview.
You'll need the components file as well.
Cheers,
Steve.
Hi STL???,
Everything was written using Delphi 5.
The OPC component I use here works from Delphi 5 and up.
All non-standard components are dynamically created so you don't have to install anything into Delphi if you don't want to. This way the examples will also work with Turbo Delphi too if you have a copy.
Cheers,
Steve.
Good stuff Steve. I have not used Delphi for ages. We used it in some of our first software here because of the ease with graphics. At the the time VB3 was not so friendly in that area.
Anyway now I have another source to point customers to when they ask me for OPC examples in Delphi.
Files you will need for all the examples and a small help file are all located in the "OPC and Delphi Components" file. The dOPC component is too big to upload to PLCs.net so there are references to Kassl's website in the documentation as you have already found out.
Steve.
I have made another example of how to use Delphi and OPC. This example has two parts: - A Server to read from and write to the PLC, display data...
1,699
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
52
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
279
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
232
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
144
