OPC and OFFICE XP
userxyz
May 2002
any
2,768
Today I had a workshop @ Siemens about OPC. I can make a connection with the PC WOrkstation Configurator now. And reading a variable in OPC SCOUT works fine.
But, we do not have Protool pro, wincc or whatever scada package. And I would try some things with OPC...
And I tought, why not in Office...
My question: Is there anyone who has an example program for me (editable), so I can understand the very basics of it. Let's say, building a macro and reading a variable ..., something like that...
THANKS VERVERYVERY MUCH !!!
Can you use DDE instead?
It is very easy to read live DDE data in Excel. It's a little more effort to write data. You'll need to write at least a tiny bit of VBA code. If you use OPC, you'll probably need to create VBA macros for both read and write operations.
There are other threads here which cover your situation. Do a quick search for "Excel" or "OPC."
AK
Combo,
HERE is a link to a description how to setup Excel with OPC.
Unfortunately it is in danish (!).
From page 9 are all the details about setting up Excel. Maybe you can grasp the basic idea from just looking at the pictures. ;)
I tried to find a guide on Siemens main FAQ database, but I couldnt locate it. :confused:
Hi! Does anybody have any experience with this product from Rensen? Initial results were very promising - point and click your way to OPC data...
2,666
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
54
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
290
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
235
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
147
