OT: Low Temperature Flow Meter
ASF
Jun 2012
Australia
3,921
I've got a client who needs to measure a flow rate somewhere in the range of 10-20L/s through a 100mm pipe. Ordinarily, not a big drama, but in this case the liquid in the pipe will be -50°C. I've got a few enquiries out with various suppliers but I thought I'd see if the good folk of this forum might be able to point me in the direction of a few options.
I'm thinking it might end up having to be a non-contact measurement method, or a DP sensor across an orifice plate. Open to any and all suggestions!
Electrically I just need a 4-20mA output and would prefer a 24VDC supply.
Try to contact flow meter sales engineer as he will help you to find right product for your applications.
I have used in the past a EH flow meters to measure liquid CO2 and there was no major issues with the device. The only problem we had was diameter of the pipe being to small and CO2 was freezing sometimes. I think it was a vortex flow meter but not 100% sure as it was few years ago.
Thanks, I've got a few sales engineers looking into it for me, one of which is E&H. I'm also going to try Yokogawa, Krohne and Emerson today.
Greetings In my project, there are three control valve One of the hot water line with a diameter of 200 Another on the cold water line with a...
3,800
hi 2 all , according to our consultants specifications,direct actuated field mounted flow/temperature switch should not be used instead...
1,996
Hi all, Trying to find a pressure sensor for an application where the process is running at -100°C (-148°F). Pressure is likely around 1 bar or...
2,943
I am sure there are plenty of people here that have used Watlow temperature controllers. We have a thermal chamber that we used to temperature...
3,056
Hi, We currently use PanelView plus 6 HMI. Is there anything from Allen Bradley in the same price range but that has a low temperature rating? I...
3,000
