OT: snowjoe motor brushes
drbitboy
Dec 2019
Rochester, NY
8,138
What do you all do for replacement DC motor brushes when you can't get them from normal channels?
TL;DR
Hi All,
Spent yesterday evening working with my son on his corded 2015 SnowJoe snow blower, which had stopped working.
The symptom was no response - i.e. the auger did not turn - to the switch turning on. The headlight did come on, so we were somewhat certain the switches were working, which turned out to be true.
We took it apart, all Phillips-head, although there was was a fair bit of corrosion we only had to drill out one screw, and eventually got down to the motor.
Once we spun the motor a few times by hand, we were able to get it to start, maybe one time in three, although it did not sound right i.e. spinning too slow (yeah fools without goggles, although we did at least remove the belt so only the motor was turning, and not the auger). There was a lot of sparking on one brush/commutator side. The brushes were carbon (graphite?) like a pencil lead, and it seemed to us that the springs were not pushing that hard. I took out the brush that had more sparks, and its commutator end was angled (worn down non-square), maybe 30° or so.
I didn't think to stretch the spring, but I did flip the brush around, so the angle was reversed, hoping to have the sharp side of the angle make better contact with the commutator. And that did improve things quite a bit: the motor ran much better (proper high-pitched whine we remember); the motor also started reliably, ten out of ten times, without needing a spin by hand to find a better starting spot.
We put it back together without too many screws left over ;). We are hopeful this hack will get him through the rest of the winter, as it took six years to degrade to this point.
Anyway, does anyone have advice where to find replacement brushes? We found a thread online where someone contacted the the manufacturer looking for brushes, and were refused brushes and instead offered a new SnowJoe instead, because they were still in warranty.
Can we wing this, make some measurements and get some similar brushes from Amazon, and shape them to fit if necessary? The spring is the conductor from the brush holder contact to the brush.
Most of my motor experience comes from the pancake motor of the Aurora HO-scale slot cars, but I suspect the principles are the same: keep it clean; ensure contact is made?
arrgh, we both have the corded versions, along with several in-laws, so taking apart the most recent one sounds like a plan, thanks!
Try ebay.
Check out the assortment (with dimensions) from this ebay vendor (lots of other vendors):
https://www.ebay.com/itm/323744064625?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D236843%26meid%3Dc5c16fba508d4e1b8e6276a38f32d17f%26pid%3D101195%26rk%3D2%26rkt%3D12%26sd%3D233172663520%26itm%3D323744064625%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeed&_trksid=p2047675.c101195.m1851&amdata=cksum%3A323744064625c5c16fba508d4e1b8e6276a38f32d17f%7Cenc%3AAQAGAAACEKKshhhi%252F21n2tOAOCTNebNh9CfhZCaT%252Bm%252FsOsNfjIKLBy9zFZ25cEprKZtRoqrl0hR%252BewJWCoPxcXPGI3kD4zWD5mPupqXmcnajJvF49u7NERtICepw12b3t95DJKflWmzudmBs7FHhU4S7N2Tie%252FFpN5rIHMM2bcXyzj%252BEFHnU28IRkBRw4hTYuDzpXIM93o7pEQU%252Btwx0IGII97YqrX0avGN%252BJZAXL4io3S0pA%252BYHHyuCkn7ClsO56SPC3jT1g0ZYMrmo4dn1PflbeuMNp7lRs9Jz9RVP%252B2sTc8Tt2AYq0c3s7Zq82cZRw2hw9msfnFDuBrL0Gykjvf4iF3ANoVjIKW%252B%252BJXDfYshf%252BHgktJEl0VkwPLJzaE5ELw49NzNR2eY3bg%252B%252Bf30mY3V0mhks%252F6rBfO79nKkIwfIsrX%252B3YV7an%252BDt7t%252BDE2fs9ut1fdPFK%252B3tVgqycU07ytqKBuckbo5AJOPRM6e2doDe%252FVvN3G%252FNFOrjzhoYMm12FMXRTQwXr8D3PreEC%252ByMhr99kkqtCr3YABgQbBBM50wIyyy0T8IK4OneOldkb6t91py2EZGpqj6zB1GVkM62VS4aNrPfpW%252BTnG%252F3C%252FF%252BOf%252B7YmcexdCFnBrjCzjzfXbRY6xuHhO7gUM8bBiqg2gT%252FIhJqkBbW%252Fp6fXiR6QjAdvgIH0I%252B6pmeFKM5VbluzEwJiAhfSwkJZg%253D%253D%7Campid%3APL_CLK%7Cclp%3A2047675
I've had luck sourcing obsolete/obscure brushes thru tool rental shops. There are "contractor" rental shops for short term rental of equipment. They might have something. Even some "big box" stores have tool rentals. Its worth a look...
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
211
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
308
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
162
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
363
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
226
