OT Tuning the Motion Control Loop Article
MikeW
Feb 2004
WI
265
FYI,
Frequent PLCS contributor Peter Nachtwey had an article published in the current issue of the engineering magazine Design News, see http://www.designnews.com/article/CA632571.html. It's clear, well written, and easy to understand as are his postings on this message board.
Congratulations, Peter, and keep up the great work of passing on your knowledge to others.
MikeW
Mike,
Yes, I've seen other articles by Mr. Nachtwey.
He does write informative goodies.
Keep up the good work Peter.
Rod
MikeW, Thanks for pointing that out.
I write the articles and seldom have time to see how they end up. What I liked about writing this article was that I was given more freedom ( words ) than what I get in most. The series that Design News is doing is called "Deep Dive" This allowed me to go deeper into tuning. What you guys might not realize is that the editors like to keep things a lot simpler but often water down to the point where there isn't much real information. I get asked to remove formulas, paragraphs reduce words count because they are to long a detailed.
I would like to get an idea percentage of readers that actually have some idea of what I am saying. If it is only 10% I think it is worth it. The key thing is that the theory works and it does make like easier. I was told by one OEM they allow a day to tune each axis. Some of these projects have 40-60 axes. Tuning all those axes takes too much time so something had to be done.
Design new did get the phi, theta wrong. They substituted a O umlaut and E dot in instead. Oops. The formulas for the tuning the Ki, Kp and Kd also have symbols that are changed. I guess they could use Greek characters. Oops again.
You guys probably know by now I don't tune PID gains if I can calculate them. I will be using this info tomorrow in a evaulation/test.
The comments at the bottom of the article seem to be from fans in the hydraulic industry that have used our product.
That had me a bit puzzled as well, I must have spent about 2 minutes trying to find the Lambda before giving up!
Hello, I have a Advanced Motion Controls brushtype PWM servo amplifier (120A10D) and not being an expert I need a simplified explanation of what...
1,869
Happy Friday! I have a two axis system made up of: ControlLogix L73 @ firmware version 24 1756-EN2T @ firmware 4 Two Kinetix 350 servo drives...
3,177
Is it possible for me to tuning 2 servo at the same time, because this servo is connected by mechanical so I'm afraid that I need to tuning them...
144
Have a logix controller and I'm using the PIDE block for the autotuner. I've got the hang of doing it for direct control things like pressure...
21
1,807
Hello all, I am using a PowerFlex 700 (Rev 10.001) to maintain tension in a web. We're reading lbs from load cells under one of the rolls...
85
11,660
