output transistor for ac current
mamentozz
Nov 2013
palembang
30
hi there, i wanna ask you something about transistor output for ac current, is that possible? because i have plc output transistor for motorize output AC, please give me hint.
Use the transistor to short the DC side of a full-wave bridge rectifier. Wire the AC side of the bridge in series with the load and AC supply.
You'll want to use opto-coupling!
Of course, you could use a relay.
This solutions looks smart...
... but this one really is. It's your choice.
If nevertheless you want to use the first solution, be really smart and calculate everything. You wouldn't want to blow up your output transistor (and eventually the rest of your PLC) because you didn't eg. take care of the heat dissipation in the transistor. Furthermore don't forget that, if you're using the rest of the outputs and in the case the outputs have a common connection, these other outputs will be on a dangerous voltage level.
Regards,
Using a relay to switch the AC power is by far the best answer. It provides protection for the PLC outputs and is an inexpensive solution to the problem.
I wanna ask you something about transistor output for ac current, is that possible?
Yes it is possible. That type of transistor is often called a Triac (meaning a Transistor that switches AC) current).
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
206
Specing Point IO to drive 3w 24vdc pneumatic solenoids. Switching frequency is approx every 3.5 sec. Math puts that at .125 amps. Debating...
2,674
Hello All, I need a bit of help utilizing a timer's DC transistor output to start/stop a motor with a VFD. The motor currently being utilized...
28
4,733
Hello, I want to ask what's the difference between relay and transistor as PLC output ? and what are the effects of npn pnp transistor to the PLc...
3,324
Hi All, I have batch controller with a passive transistor output. This controller receives setpoint input from operator, when that setpoint is...
3,823
