FernandoPLC
- Join Date
- Aug 2004
- Posts
- 3
I have A PLC CQM1 CPU 43
With a Output Unit OD212
Output 5v to 24V
The program that I did works correctly, is loaded in the PLC correctly. The PLC does not mark mistakes and does not alarm. The LEDs in the Output Unit ignite well, but it does not give voltage, already check with a multimeter and it measures 0 volts
I don't know if the Output Unit has to be configured or that it should do.
i need HELP
Output 5v to 24V
i need HELP
