PanelView Component Not Supported?
gbradley
Apr 2002
Corona, Ca.
1,637
Why is there a warning in CCW that the PanelView C400 is not supported?
NOTE: PVc applications created for PanelView C400 TFT terminals are not supported by PVc DesignStation 2.0 and Connected Component Workbench 1.0
It seems to work.
The PanelView C400 was an addition to the PanelView Component line that happened after the initial 2/3/6/10 inch models.
I suspect this is just a notification to let you know that you won't be able to take this PVc application and open it with the older CCW 1.0 or PVc DesignStation 2.0 software.
My newly-installed copy of CCW 1.1 displays the same "PanelView Component DesignStation 2.10 (1.60)" revisions and shows the same Not Supported warning.
Maybe somebody on the Forum still has CCW 1.0 and can verify that the 2711C-T4T is not in the hardware Platform list.
I see, it's new, and that's why it is not listed in some of the publications like the selection Guide"view-sg001_-en-p.pdf"
So it is not supported in the previous version of CCW because it is new, not because it is going away.
It looks like it will fit in the same cutout as the 2711C-K3M.
Thanks Ken, I always appreciate your replies.
Does anyone have access to a programmer's manual for this? Specifically, I am looking for instructions for the advanced toolbox objects such as...
1,050
I need to get an upload from a 2711C-T4T. I found an old thread http://www.plctalk.net/qanda/showthread.php?p=734222#post734222 on here that...
1,969
I am using a PanelView C1000 as the display and a MicroLogix 1400 as the controller. How do I use a floating point address (i.e F8:0) from the...
1,437
I have a working collection of applications for the PVC C600. the setup is one pvc600 connected to a DH485 network with two micrologix 1200's...
1,576
Hello everyone, I have a 2711C-T4T with firmware 1.80. I am using Connected Components Workbench v10.00 to attempt to download an application to...
2,692
