Panelview Multistate showing question marks when I convert to french
daviper1996
Jun 2010
roseville
I recently added several new screens with multistate indicators. While in English they are fine. When I switch to French they turn to question marks. I thought since they are only numbers it would not be an issue. Is there a work around or will I need to change objects?
Thank you
Solution
I looked around some more and found the option in Menu / Tools / Languages
Check "Display undefined strings using the default language"
This kept my numbers displayed on the indicators for both English and French.
Hope this helps someone or even myself in a year or two!
Hi, This is my first post and my first time programming a panelview plus 1250. Im looking for some help with something I am trying to do with...
1,360
In FactoryTalk ME I configured a PLC COmpact Logix In the RSLinx Communication setup to be called "checker" with a shortcut It verifies that...
2,693
Using Factorytalk view ME and RSLOGIX5000 I am trying to use a multistate indicator on my Panelview plus that will become visible and display a...
10,555
I am new to using the Panelview 300. I notice that when I first enter a screen that includes a multistate indicator, the Error State message is...
1,985
How do you determine what a multistate indicator is going to do when it is pressed? I have an existing application with a gotoDisplayButton...
12,461
